P0306? Can be several causes: http://www.obd-codes.com/p0306
P0135? Usually the heater coil in the sensor burns out. Can be wiring or the PCM.
So what does this mean...did the code come back up on a different cylinder, or did it not? If it did, then I would suspect the plug may have a small crack, incorrect gap, etc. If not, maybe the plug wire.I pulled the plug on cyl 6 and it looks to be ok, today I moved the plug from #6 to a different cyl to see if the code pops up again but on a different cyl this time. Any ideas what commonly causes misfires on these engines?
So did the problem start with the new plugs and wire?The van got new plugs and wires last summer
The code hasn't come back yet because I still have to drive the van more lol, but yes gonna keep an eye out to see if its on a different cyl or it stays on #6. The check engine light doesn't flash and it does not come on instantly, usually I have to drive it for a few days to a week for it to come back. And the problem started about 2 months ago so about a year since the new plugs and wires, thanks for responding!So what does this mean...did the code come back up on a different cylinder, or did it not? If it did, then I would suspect the plug may have a small crack, incorrect gap, etc. If not, maybe the plug wire.
Thanks for your response! Would a new o2 sensor fix it you think? Also I have bad gas mileage could the 02 be the culprit?P0306? Can be several causes: http://www.obd-codes.com/p0306
^^^ I like these answers a lot ^^^Since you have a 2002, you should check the wiring harness for the fuel injectors.
I am surprised nobody has mentioned it yet.
Please see this thread:
Melted injector wiring harness 2003 Town and Country
http://forum.chryslerminivan.net/sh...injector-wiring-harness-2003-Town-and-Country
One other issue as the vans age is the coil pack
Here is one thread on it:
P0302 code, how to test if coil pack is bad?
http://forum.chryslerminivan.net/showthread.php/30794-P0302-code-how-to-test-if-coil-pack-is-bad
Good luck
Yes these vans don't agree with any other brand of spark plugs other than Champion Double Platinum. I think the Bosch brand doesn't agree with these vans at all lol!Hey guys I think I may have fixed the problem! I had these weird bosch plugs with 4 grounds over the electrode and my friend told me those plugs are absolute crap, so I threw a set of champion platinums in there and just drove it, no more popping! Ill drive it for a week and keep my eye out for codes! If that was the fix, everyone stay away from those bosch plugs! Thanks all![]()
You DID remove the outer sheath to check the wires inside, I hope. :Wow1: The damage is not readily apparent from the outside. That is why many owners (and pro mechanics) miss suspecting harness damage ass a cause of their maladies.yes the wiring harness which I got a nice look at when I changed the coil looked to be in fairly decent shape, not burnt or melted through thankfully!
