Recently bought an 02 Grand Caravan that stutters hard under 2k rpms at about 45-55mph on acceleration. If I turn O/D off, it doesn’t do it because it doesn’t reach top gear, or if I give it enough gas that it downshifts, it’s fine. It has a slight miss at idle, only gets about an avg of 19/20mpg on the freeway, 13-15 in town. The stutter feels like when you hit the rumble strip on the freeway, but HARD.
Changed the spark plugs which were horrible with no improvement and changed the oil because I know that needed done. Not sure where else to start looking, beyond firing the parts cannon at it, which I really don’t have the funds or patience for. Done some research and nobody seems to have had quite the same problem.
Additionally, the CEL is on for a cyl 2 misfire, which I don’t believe changing plugs fixed, as well as an EVap leak. Plug Wires seemed to be intact.
Any help appreciated, I can give more info if needed. Praying it isn’t the tranny, the fluid is at the appropriate level and still has good color. SLIGHT black particulates if anything. TIA.
