I'd do the key dance to read the code. THEN, before I rolled out Buff's "Parts Canon" I might even swap the sensor from the right side to the left side. OR unplug them one at a time to determine by elimination one by one to ensure that I know which sensor is really the fault.
THEN I might try the left sensor on the RH side (if they are interchangeable) just to prove that the sensor repacement is going to fix it. (If you can swap sensor from left to right and the fault follows the sensor then you are pretty sure you have nailed it in diagnosis) (That is what I did on my 2002 rear sensors and then I put the good one back and replaced the dead one Amazon) Less than $25...
I went to salvage today and the guy charged me $8 for a used side door mirror when I could have gotten a new mirror Amazon/eBay for $9.99 delivered.... You Pull is not GREAT deal anymore. Greedy for something that will be shred and crushed.
