So my first post. Please forgive any guidelines I'm not following. I will try to be a better member in the future. Here goes.
Just bought this van 5 days ago. It was a buddies. He got it from a no great reputation car lot. 3.3 09 grand caravan, remote start, power doors all in the remote. This info may or may not be useful for diagnosis.
Wife was driving about 1 minute after leaving a gas station, maybe 30 seconds it died in the middle of the road. No CEL. Won't crank, only dummy light is a battery light. Headlights are bright, all windows and doors working. PRNDL is not working as I cannot shift out of gear unless I hit the release above the shifter to bypass the interlock solenoid. Push it out of the road. So I start racking my brain. " What would kill the car while driving and keep it from trying to start again. I could come up with nothing but possibly computer or ingition switch. So I research so to find out these vans commonly have issues with those things and the fuse box and the key. So great.
I go to a junkyard and get a new WIN module and key. Put it in, and it changes nothing. But works my doors and locks my doors much better. So figure it wasn't the problem but it is functioning in the van better than the other.
When I turn the key there is nothing but a couple relays in the Tipim or fusebox, and it also will not shift into gear. Check voltage to the battery 12.3. so figure that's not the issue.
I go to junkyard and get a computer for 40$. Put it in, no change everything identical to before. To rule out the battery I put in a different battery that I use every day in my truck. It changes nothing. Test voltage at the starter, no voltage. Even with the key turned to start. So I lift up my Tipim, I see a wire has been sloppily tapped from a connecter way back like 8 inches. It's a bare wire under there and the pin is loose and the connector has melted, right where it plugs in the area affected relay wise is the ASD relay. So bam I have found the problem right. Not exactly. Went to the junkyard found a nice plug, cut it off and replaced the burnt one with the nice one. Different battery, ignition, computer. Found a fuse popped that said it was related to the transmission and battery, 10 amp. Changed it. Hit the key, cranks over and starts runs for 2 seconds and shuts down. Start it again, same issue. This whole entire time the vehicle wouldn't communicate with the scanner. The reason I bought the WIN unit first was because that was a symptom of the win going bad. No comm w vehicle. And that continues until I am able to get it started and it dies. So I then try to communicate with my scanner again, it works. Says w never a check engine light shown that the EGR is a stored code, and a pending code. So pull it off and clean it well. Somehow now after it's clean and reinstalled, the van doesn't want to start again. Check the same fuse we changed before its not popped. Tried switching computers back to the stock one to see if it would start again and maybe stay running. Negative. No crank no start. The popped the same fuse as before. So swap the WIN back for the original. Thinking maybe the two stock peices needed to be together to communicate to the vehicle nothing was different. No luck just popped the same fuse. Swapped computer back to junkyard one. No crank. Put junkyard win back in. No crank. So that's where I'm at after 2 hard days of attempts at repair.
My only thought now is maybe Tipim although that it looks like it's fine isn't actually fine at all, or I have some more grounds I need to find and clean up and fix. The only grounds I have been able to find to clean were two time lil chassis grounds near the fusebox.
I'm so stuck at this point. I know my orig computer is popping that transmission fuse and that acted like it was the one thing when repaired let the van crank on its own key and run. It did this with both ignitions as well.
So computer seems to be bad because it popped fuses that kept the van from starting.
Battery was bad because when we tried to jump starter at the relay with a wire it barely rotated enough to make noise. So dead cell maybe? Different battery it would spin and spin. But had it cranking and running for two seconds at a time, everytime. Rescanned it finally communicate vehicle says EGR. Pull it off hoping that's what's not letting it stay running and now it won't crank again. Fuse hasn't popped. Just won't crank on the key again. Tried swapping relays, got a pocket full at the junkyard.
Tipim or grounds is all I can think of I haven't addressed, of the problems I know about. When it started it didn't struggle to start and once I was able to reach over and pat the gas once. Oil light did pop on when it dies every time. Oil sending unit then? So like 4 things went wrong at the same time.
