Just read the whole thread. Enjoy watching a build snowball to bigger/better things (more powar!
Should have just used the 4th gen heads, with bigger valves and 7 rocker shaft bosses instead of 4. Better design. Also, 4th gen cam has more lift.
I once fit a 4th gen lower intake manifold into a 3rd gen engine in a junkyard, so I know it will bolt up. When I was driving my 3rd gen, I was wondering if using the 4th gen intake and exhaust manifolds would boost power. The 4th gen exhaust manifolds flow the best. The shorter runner 4th gen intake plenum would have lost some low-end torque though.
The 3rd gen rear axle fit into a 2nd gen body? I kind of did the opposite; put a 2nd gen rear axle under a 4th gen van, and it was narrower by 1 1/2". I had to use ratchet straps to suck the leaf springs together to get the axle bolted to them. I did it so the body could roll onto a trailer and get hauled away, as I was keeping the original rear leaf springs/axle for spare parts for my other van. Since 3rd and 4th gen vans share the same rear axle/suspension parts (well, early 4th gen anyway), wouldn't that make the 3rd gen axle too wide for your van?
Cars are like big puzzles to me. It's amazing what you can take apart and fit together, from totally different vehicles.
