Yes, but it shouldn't have fit! The 3rd gen axle is over an inch wider at the leaf spring mounts. You should have had to move the leaf springs outward with the forward mounts and the rear shackles somehow.I installed the 3rd gen axle so I could put 4th gen hubs, backing plates, Calipers, and rotors on the van. I removed the weight sensitive proportioning valve and installed an adjustable Wilwood proportioning valve.
