Differential Spider Gear Shaft Retainer
I am installing these retainers on the 41TE Transmission Differential. They prevent the Spider Gear Shaft from falling out and turning the Transmission into a large paperweight.
Even better if you go pull the entire differential carrier out of an 04-07 Pacifica or 4th gen minivan. They have a fully enclosed, or windowless, differential carrier.View attachment 72130
I compared the 1991 and 1992 3.3 L V6 Fuel Injection schematic diagrams. It appears that there are only a few differences between the two years. If I cannot get a 1992 wiring harness, I will rewire the 1991 harness. The Fuel Injector circuits can be changed by rewiring just three injector wires and connecting them to the appropriate pins on the ECM. That will convert the injectors from batch mode to Sequential mode.View attachment 72120
1991 Dodge GC Injector/Sensor Harness
I checked the Injector Harness wiring from my late-1991 model GC to confirm it has SBEC1. It has the SBEC1 style batch paired injector wiring. The injectors fire in pairs: 1/6, 2/3, 4/5...
I am looking for a '92-'93 Injector Harness.
The bearings are pressed onto the gear. Just make sure to keep track of which shim goes with which gear. The necessary shim is determined by the transmission case. So, you want to reuse your shims, not the donor shims.I will get a 3.8 L gear pair at the wrecking yard. I ordered a 1.5" impact socket today for the output gear nut.
I will see what it takes to swap the gears
It may take a new bearing.
There are no spider shaft retainers installed.
I decided to get 3.8 Ring and pinion set instead. That will give me a 3.91 final drive gear ratio. Now all I need is a higher stall speed torque converter.The bearings are pressed onto the gear. Just make sure to keep track of which shim goes with which gear. The necessary shim is determined by the transmission case. So, you want to reuse your shims, not the donor shims.
