1 - 9 of 9 Posts
My 1993 Dodge Caravan (AWD) with 200K miles & a 3.3 has an Intermittent Idle & electrical interruption problem. When idling or under light acceleration the engine dies for a split second; all gauges fall / bounce to zero, and the radiator cooling fan, A/C compressor relays click (open) when this happens. All interior lights dim for split second and seem to flutter like a voltage fluctuation(?) is happening. Engine idle usually recovers, but when idle settles down, the problem ocurs again- intermittently. Sometimes when engine idling, it stalls completely, but will restart but only after after returning the ignition to "off" first (to reset fuel pump relay?). Problem happens at different intervals; sometime runs for a couple of minutes to a half-hour with no problem, other times happens repeatedly every few seconds. Engine runs fine in between occurances; moderate to wide open throttle is normal & engine pulls fine. Problem happens more when cold, but still occurs when hot. No ECM codes- reads 12 & 55 (normal?). Battery & Alternator are nearly new and are working fine- no voltage fluctuations there.
Chrysler dealer did diag & said is bad ECM, I replaced it and same problem. Local garage did scan and all readings appeared OK, except EGR showed "blocked". I replaced the EGR Valve & its vacuum controler; no change. I replaced the TPS, and removed & cleaned throttle body; problem same. I checked the ignition switch visually & inspected the pig-tail connector and it appears OK, no signs of heat or corrosion on the connections. Anybody out there have any ideas and / or some electrical schematics I can get a hold of and check some voltage readings at suggested check-points? I've read some other sites which suggest a "Power Module" voltage drop causing power relays to open interupting power (Z1? Z2?) to the ignition coils, gauges, fuel pump, cooling fan & A/C, etc. Where is the "Power Modual" on this unit? '93 models do NOT have the Auto Shut Down & Fuel Pump Relays on the left inner fender like the earlier vans did- I think. Someone suggested a bad MAP sensor, but this van does not appear to be running rich; it runs like a bear and I don't want to have to give it up for something like this. Help! Thx, Matt In SC
A good clue here is you have to cycle the key off/on before it will restart. 1 thing that can cause that is if the 8 volt supply (orange wire that power the cam and crank sensors) get shorted. Look for damage to the cam/crank wiring, possible bad sensor(s). Cycling the key resets the voltage supply from within the module.
PS; no "power modules" since about 1987??.
My old 93 had a similar problem when I had it years ago. It would do that when going down the highway. just every once in a while the gauges would all drop and return. And if I was in cruse control it would release and had to be reset. I never did find the true cause but was told that 93 had a software glitch problems. I just lived with it.
Hank
My 2 cents , sorry I didn’t read the entire post I’m a ass and looking for a 2nd gen body control module BCM wiring Diagram but I had a intermittent stalling Issue related to air bubbles in the coolant jacket , throwing the coolant temp to choke you could keep it alive but would stall at any speed under 5mph
P.S. uninstalling and reinstalling the coolant temp sensor after air passes and coolant gushes out solved the majority of my stalling issues 93 GVoyager 3.3 /2.3 v6 FWD , and remember safety third never work on a hot coolant system as you’ll likely get scolded. literally , at least throw a rag over first if your in a tight situation and don’t pollute coolant is toxic Especially to anything with taste buds I hate the internet world is ****ed
1 - 9 of 9 Posts
