1 - 4 of 4 Posts
It starts ok and runs ok until the first stop sign or light. It then starts to buck and will cut off. Placing it in neutral causes the bucking to stop. Once it's all warmed up every thing is good. The torque converter is linking and adding stop leak improved the problem, but did not eliminate it. The shop says there are no codes. I've been using this shop for about 6-8 years and they are pretty reliable.
1993 Grand Voyager(3.3 L) -- Bucking when cold Reply to Thread
The TC is leaking. Put stop leak into the transmission dipstick access.
1 - 4 of 4 Posts
