1997 plymouth voyager Ralleye version with ultradrive transmission
2.5K views 11 replies 5 participants last post by  Evon Trizmo
Limp mode is second gear, and I would not be driving it around at those speeds in second gear. Since second and reverse work, that means the basic hydraulics are good. I don't know what those codes mean, except 700 is a general transmission fault code. I'm guessing the inside of the transmission pan looked normal? Could be a wiring fault or a bad solenoid pack (box thing on front of transmission).
You've had good luck with not blowing the engine. Still needs a solenoid pack or a transmission. If you don't want to fix it, keep driving it until something breaks and strands you, or sell it as a repairable with transmission issues.
Reactions: mcquaderichard
