Latest update....
1. Re-checked all my electrical connections and voltages
2. Have 12Vdc at starter large diameter wire
3. Have 0Vdc at solenoid wire (small diameter wire at starter) with key to start
4. At relay prong 86, have 12Vdc (from prong hole to battery ground) with key to start.
My assumption:
The wire from starter relay to the starter solenoid is "bad".
Assuming that the wire didn't come off the bottom of the relay box, or it's not severly corroded:
Is it a direct connection?
Can I just replace the wire (if so, which one actually is it that connects to the relay?)
Lastly, how do I get to the wires under the relay box?
Thanks for all the help!
No you can't assume that yet. 3 things have to happen before you get voltage at the solenoid connection at the starter. 1) There has to be 12 vdc to the relay coil. You proved you're getting that at contact 86 on the relay socket. 2) There has to be 12vdc waiting at the power side of the switch contacts in the relay. Check for 12vdc at contact 30 on the relay socket. That voltage should be there all the time. It comes from the battery then through a 40 amp fuse #9 then on to the switch contact. 3) The relay coil has to be energised. For that to happen you have to have power at contact 86 (it's there)
and a ground to the relay coil supplied by the PCM. Here's where I'm fuzzy. The ground is switched on by the PCM, but what is the PCM looking for to switch the ground on?
I can guess and say the PCM is looking for an input from the securtity system start immobilzer telling it all is well or the Transaxle Range Sensor (TRS) telling the PCM the van is in park or neutral. Maybe someone can fill in that blank. In any case, you could try disconnecting the negative battery lead for a few minutes to reset the security system or jiggle the gearshift to reset the TRS.
If all this is turning to mud, a picture might help. This link will get you there:
http://www.oplin.org/databases/proxy2/proxy.php?qurl=http://arrc.epnet.com/autoasp/framerq.asp Takes a bit to get to the diagram:
Type 123456789 in the password block
Scroll to Cincinatti library and click submitt (give it time to load)
Scroll to ARRC
Select 2001 then Dodge Grand Caravan to get diagrams (applies to T&Cs)
Select wiring diagrams then starting system
Everything I've talked about is based on this diagram. It's a simple diagram, unfortuneately, it doesn't tell us everything we need to know. If you draw a line from the middle top of the diagram to the middle bottom, it should bisect the starter relay. Looking at it this way everything to the left of the line energises the relay coil and everything to the right works as the result of the coil being energised.
