1 - 2 of 2 Posts
Cylinder 4 miss fire
Error code P0108
Circuite high input
Initially it was giving a different code but after reset its giving p0108. After computer reset It was fine for 2 minutes and again started mis firing.
Compression and fuel pressure 160 psi, 40 psi
Map sensor changed
Coil is tested
Mechanic cannot determine root cause please help.
youtube.com/sideburns2009
If it only does it after then engine has warmed up, it could also be the coolant temp sensor (which usually doesn't give a code). I would say wiring but if it's working after a reset, i'm guessing pulling the battery terminal to reset the PCM, then I wouldn't think it would automatically fix a wiring problem.
EDIT:
http://www.helpforcars.net/obd_codes/codes.php?code=P0108
1 - 2 of 2 Posts
