1 - 2 of 2 Posts
· Registered
My wife's a/c won't stop blowing turning it off or changing the dial doesn't effect it. About 3 weeks ago the a/c didn't work at all and about 1 1/2 weeks ago it just started blowing.
Anybody else have this issue?,
Anybody have any suggestions of what I might try?. Anything would be much appreciated, Thanks
· Drivin' Maniac
2002 Grand Caravan ES 3.8L
Just to verify, does your T&C have 3 zone automatic climate control?
Most likely, your fan controller is toast. It is located behind the glove box. It is easy to replace, but more expensive than the resistor found in manual A/C models.
If your T&C has a cabin filter, you will want to replace or clean it regularly. Poor airflow through the filter causes the controller to run hot and fail.
1 - 2 of 2 Posts
