1 - 8 of 8 Posts
2003 Dodge Grand Caravan SE, 3.3l Flex, 175,000 miles
I unexpectedly lost coolant and over heated when running the A/C. I added water to get home and an inspection of the system revealed what appeared to be a snap-on connector (elbow, 1 side clamped) in the rear wheel well was dislodged. I was able to snap the top half of the elbow back on. Although I've mostly been running the heat, it doesn't seem to be leaking.
My question is what's the name and part number of the elbow and is the male end prone to problems and should it also be changed? That end runs into the rear compartment.
From a post by J. Whikoff:
"I think the whole bundle of lines is 5183255AA. Discontinued but still available through Summit and other places. Maybe I'm looking at the wrong part but it looks like they changed the elbows into a formed hose, and would require a lot more work to replace than just the elbow. Brilliant...
If I look at '05 instead, I found 5066525AA. That looks like the elbow and short section of hose. Give that a look."
Someone else replaced that hose/elbow with a longer silicone hose and smooth hose clamps, because the plastic fittings crack and leak.
61407
Reactions: itsallgood
Discussion Starter · #4 ·
Yes, that's it. Thanks. I'll keep the rear A/C off for a time and see it it makes any difference.
That's a heater line, not an air conditioning (A/C) line. Flow is continuous through the heater lines, there's no shut off valve, hasn't been since around 1995.
Discussion Starter · #6 ·
Frankly, I have no idea how the rear A/C and heater work. The day it popped I the A/C running. Once I popped it back on, and refilled the system, I haven't had to run the A/C and I'm reluctant to run either in the rear compartment.
The A/C is completely independent of the heater except for the fan. Likely don't need either one in the rear for normal operation day to day The rear heat lines can be bypassed quite easily, near the front, underneath, by using one hose as a crossover to the other line.
Reactions: Hiker
Discussion Starter · #8 ·
The problem stopped for several months but it's got to the point something has to be done.
Can you better describe how to make the bypass/crossover repair?
1 - 8 of 8 Posts
