2006 Dodge Grand Caravan 151K. A few years ago I lost the coil, only the number one was not putting out anything.
so I changed the coil. A couple of years later the same thing happened, only number one. So I Changed the coil again. Six months later the same thing. So I changed it again two weeks later the same thing. So I start thinking it just did not burn in well. So I replaced another, two day's latter it is gone. So I study a little and get a new ECM with a new coil. Two days later same problem.
So off to the mechanic, it goes. My normal guy call's me a say's up front, to take it to an auto electric repair. We take it there, and I had asked while they were working on it to put in a new set of plugs and wires. Once they got to it. They tell me it is fixed and it was the plug wire that was the problem and that they changed the plugs and wires and put in the new coil and it should be fine.
Two days later, you guessed it, it is starting to act up like before. I have not lost the number one yet, but once the engine has been in operation for 20 or 30 minutes that same sublet miss seems to be coming back.
I have no clue at this moment as to what could be causing it.
I know years ago I had a car that would just basically start running so rough you would need to pull to the side of the road and let it cool down. I eventually walked down a wiring harness to find two wire partially melted together.
so when it got hot, they would crosstalk. Once I pulled them apart and moved the harness, I never had a problem again. But with my van, I am lost.
So ECM has been replaced with new coil, plugs, and wires. The same and only coil output is going bad again.
Has anyone seen this?
