1 - 7 of 7 Posts
When i turn the key on nothing happens. The dash lights and radio do come on tho. Checked battery and cleaned terminals and also replaced the Starter. It's not engaging the Starter at all. What else could be wrong?
2009 GCV SE
Hmm, so you've replaced the starter, and since all the lights and radio come on when you turn the key but doesn't crank could indicate a bad connection between the battery and the starter itself, (hopefully) I would firstly check the connector on the starter, make sure it's plugged in properly, then I would visually inspect the wires going to and from the starter. Check to see if any of those wires have been damaged in any way.
Otherwise, I found a self diagnostics page that can help you try some things and pinpoint what the issue might be:
Why a car won't start - troubleshooting tips (it's not specifically Chrysler but worth a try)
Try to start it in neutral, if it does it, then your neutral switch is bad.)
Thank you. I'm going crawl back under it and triple check everything again. I'm slightly concerned that one of them might not be tight enough.
Ok. I'll give that a try. I didn't try starting it in neutral but did take it in and out of gear. I'm concerned my TIPM is bad again. It's doing very similar things that it did before that got replaced about a year ago.
2009 GCV SE
Good afternoon, did you end up resolving or checking the items listed above by members?
1 - 7 of 7 Posts
