1 - 7 of 7 Posts
Just like the title says. I have a 3.3 v6 i went to change the timing gear and there were no guides. Videos all show guides in the center. There is no place to put the new guide as there is nothing to screw to the motor to hold it. Can anyone confirm?
Rockauto.com kits don't include any guides. The setup is pretty simple, straight up and down. Short chain.
The older blocks might have had the center piece.
TIMING CHAIN KIT PART NUMBER # 4M-3CY086-1
COMPATIBILITY:
CHRYSLER 201 / GRAND CARAVAN 3.3LTS / DODGE INTREPID 3.3LTS 90-03 (5 COMPONENTS) WITH DAMPER & FLANGER
Rectangle Auto part Metal Fashion accessory Circle
Compatible with a 1995
Not compatible with a 2005 nor 2010
If the chain is as tight as it should be, guides are useless.
Reactions: 97K15004WD
1 - 7 of 7 Posts
