1 - 4 of 4 Posts
I only have one key fob and it is acting up, so I ordered 2 fobs, then found out you need 2 working fobs to program the new fobs. NUTS any way to work around this issue.
Open the old KFOB, remove the electronics, clean contacts with alcohol, install it in the casing of one of the new KFOB.
You should be good to go.
If you haven't done the ignition recall yet go do it. They'll give you 2 brand new FOBs. That's what I did.
1 - 4 of 4 Posts
