1 - 2 of 2 Posts
2010 Town & Country. Passenger side sliding door won't open/close except manually. It will "click" when trying to open and when trying to close also. If I manually open the door and then press the pillar button it will open the rest of the way with power. It will not close at all with power. ALSO. the power window to this door will not work anymore. ALSO, the heated seat to this door (2nd row passenger) will not work either. Could this be a fuse/relay ect?? Seems funny all this happened at the same time and basically to the same area? ANy help would be GREATLY appreciated!
Thanks, Mike
Another member had an issue with electrical parts and it was found to be a cable issue. I am wondering if your problem is similar.
I hope it is still under warranty. It sounded expensive to track down unless you are able to do so yourself.
1 - 2 of 2 Posts
