What are the application instructions for ThreeBond RTV? 1184?
That was the MSDS not application instructions.What are the application instructions for ThreeBond RTV? 1184?
Interesting. Normally instructions are to go around bolt holes but ..... I guess ..... it's sort of okay, considering. I think covering the mating surfaces is better though. Think dirt and rust in the empty spaces.The correct answer for this engine is 12 NM torque and the application guide for the RTV is a 2 to 3 millimeter wide bead of RTV around the perimeter of the sealing lip or flange with the bead running on the inside lip of the bolt holes. Working time is 20 minutes and let the RTV cure a minimum of 45 minutes before adding oil.
I guess Model A just felt the need to post something.
Model A has given this advice before. Works for him, maybe not so helpful for others.5. Apply a continuous and even bead of silicone to one surface, first tracing the internal areas of the gasket configuration, then all surrounding bolt holes .....
That's why gaskets are better, full coverage of mating surfaces and no sealant plugging the bolt holes.As a general rule if the pan bolt holes are not through holes I do not encircle the bolt hole with sealant.
I was going back and forth about using a gasket instead but decided to go with RTV as that is what came out of the factory. The two factors that drove me away from a gasket were;That's why gaskets are better, full coverage of mating surfaces and no sealant plugging the bolt holes.![]()
The torque for the transmission pan bolts is 105 inch-lbs (12 Nm), according to Haynes and others. People are using that successfully for regular gaskets, including Fel-Pro.I was going back and forth about using a gasket instead but decided to go with RTV as that is what came out of the factory. The two factors that drove me away from a gasket were;
Adding a gasket changed the dynamics with torque settings and none of the gasket manufacturers supply torque specs for using their gaskets.
Also reported issues with gaskets splitting and oil pan bolts working their way out when using a gasket due to improper torque.
