New-to-me 2013 Grand Caravan RT with 119,000 miles. After the van has been driven around 20 minutes it will start stalling inconsistently at stops, prior to this it runs great before warmed up. Just prior to stalling the RPMs bounce around 500, and if shifted into neutral quickly the van will not stall and I can idle fine at the stop, but when shifting back into drive it will stall unless gassing it quick. Also when it dies, it will start again fine in neutral or park, but when shifting to drive it will want to die again. There are no check engine lights on. Sometimes it will do it every stop, and sometimes 1/10 stops. In order to fix this the previous owner had the transmission, torque converter, solenoid block, and TIPM replaced recently which did not change anything. I have a new MAP sensor on the way. What else could be causing this problem? Thank you so much for any advice.
