I am starting to see oil on top of my transmission, and have intermittent oil usage, so it seems the Achilles heel of these 3.6 motors is rearing its ugly head. Any thoughts on which new oil cooler to purchace? Or to stay away from?
115K on the van...I am starting to see oil on top of my transmission, and have intermittent oil usage, so it seems the Achilles heel of these 3.6 motors is rearing its ugly head. Any thoughts on which new oil cooler to purchace? Or to stay away from?
Buy a Mopar unit, ensure no one is overtorquing the cap from now on. Problem solved.I am starting to see oil on top of my transmission, and have intermittent oil usage, so it seems the Achilles heel of these 3.6 motors is rearing its ugly head. Any thoughts on which new oil cooler to purchace? Or to stay away from?
I used to think the plastic oil cooler was the Achilles heel, until everyone started posting about failed rocker arms leading to camshaft wear, postsI am starting to see oil on top of my transmission, and have intermittent oil usage, so it seems the Achilles heel of these 3.6 motors is rearing its ugly head. Any thoughts on which new oil cooler to purchace? Or to stay away from?
I mean the 4th gens also suggested 50k change intervals much like the 5th gens suggest 60k intervals (the 120k interval is only in pure highway use). Oddly enough the 41TE still had loads of failures despite it's 20+ years of updates and upgrades.Add to that the factory fill transmission fluid that starts to die at/before 100000 miles. that's suppose to last for at least 120000 miles under normal use. I wonder where they got that poor performing ATF+4 from.
Seems the ATF+4 that came with the 4th Generation 41TE was a better product. Some never changed it, wasn't required under normal use (basically no towing/heavy hauling).
Nope, not at all.I mean the 4th gens also suggested 50k change intervals much like the 5th gens suggest 60k intervals (the 120k interval is only in pure highway use). Oddly enough the 41TE still had loads of failures despite it's 20+ years of updates and upgrades.
Otherwise, no transmission fluid/filter change is required. Zilch again.This maintenance is required only for police, taxi, limousine type operation, or trailer towing.
This has nothing to do with city driving, highway driving, cold, hot, uphill, downhill, or whatever what one might imagine. It is very clear as to what requires more frequent fluid/filter changes and is consistent with the 4th Generation.Change automatic transmission fluid and filter if using your vehicle for any of the following: police, taxi, fleet, or frequent trailer towing.
The 1990s? Much higher, I think, if body rust didn't do them in.In 1930, the average life expectancy of a new vehicle was 6.75 years. That could be about 50,000 to 90,000 miles depending on how individuals were using their vehicles. It would be rare to travel long distances in the thirties. In the fifties, sixties and seventies, cars improved to last about 100,000 miles.
I'm not sure where or how this trope started, but this **** needs to die.Car's up into the mid 90's were never expected to last 100k miles.
Just like the plastic intake manifolds that were first used over 20 years ago. And started being replaced 10 or so years ago in quite a few cases. Some appear to outlast the engine, some don't.The plastics and polymers used on engine components were not chosen out of the air. They are not the plastics used in legos and nerf guns. If you look at the material used on the intakes and the oil cooler- it is a nice quality plastic that is used. Replacing it with cheap grade cast aluminum is not going to prevent a Gorilla from overtorquing and cracking the housing.
That also may not be the failure point. I did not see any cracks in my cooler when i took mine off. The seals between the top of the engine deck and the cooler are the only things preventing leak-- over time, I suspect the seals fail- loose compliance, and compression, stay fixed. The engine deck itself at the seal points is perfectly smooth, there is no machined recess for those seals to sit inside or compress into. - you are reliant on those seals having counter compression onto the flat surface of the deck to provide the seal.
10 years is a long time, 100k miles is a lot of RPMs, and many, many heat cycles. Car's up into the mid 90's were never expected to last 100k miles. Maybe the VW/Mecedes versions are lasting longer because they are Euro.
Word of free advise, Replace the PCV valve if you haven't done so. Oil will start to leak thru different points if the engine can't breathe correctly.I am starting to see oil on top of my transmission, and have intermittent oil usage, so it seems the Achilles heel of these 3.6 motors is rearing its ugly head. Any thoughts on which new oil cooler to purchace? Or to stay away from?
