The airbag light in our 2014 Grand Caravan goes on and off intermittently. It was rear-ended (submarined) by a lowered / riced out Miata a couple of years ago. The airbag and light didn't go off then. A month or so later my wife accidentally ran over a speed hump in the road at 35+ mph. The airbag light lit up then. IIRC, we turned the key on and off several times and it cleared the light temporarily. Since then, it has been coming on and going off sporadically. What seems to trigger it is taking a full lock turn in a parking lot in either direction. It makes me think that a sensor is causing it. I searched the forums and found the "corroded 4 pin connector under the seat" fix, but haven't tried it yet (see note below). I also tried the "leave the battery disconnected 2 minutes" fix and it still came back on. Is it possible to re-set the air bag module? Any other ideas / thoughts?
I ordinarily do my own work on vehicles, but I've downsized to a condo and working on cars on the premises is a no-no. I don't trust the $tealer$hip to (attempt to) do this repair, so I'm doing some research before I take it to an independent / old school garage.
