Hey, the GF has a 2017 Dodge Grand Caravan that currently has 145k miles. When on the highway at cruising speed if you go to pass and mash the throttle it drops a gear (to 5th i believe) and just revs out as if it where slipping. However it doesn't pull at all even intermittently as a slip would. Its like its revving out to 4k in 5th gear and coasting. Ive read on here and came up with TCC solenoid. What is your guys take and ideas? I do have a scan tool (obd2 usb + diagFCA). Do I need to scan it pull live data from a drive? I appreciate the heads up.
Also ive flushed this transmission filter and fluid 2 times, 1st at 90k 2nd at 130k. Always change oil at 5k miles or 4 months, use chevron injector cleaner. Trying to keep it mechanically happy.
Thanks Nick
Thanks Nick
