1 - 4 of 4 Posts
Proper o ring placement. O ring goes near top of last thread Or above last thread in a small channel with a short wall at the bottom ?
Don't overtighten the cover!
Reactions: Scot_W
Tks, and yes, just below the small channel at the top as shown in your clear picture. Tks.
10-5-22 2019 3.6L van
After cool down oil filter cap was removed and yes the o ring was in the wrong groove and was gently moved lower to be correct. While filter was out the cap only was put back on and tightened enough to bottom out and cap was marked then loosened a couple of times to try again then filter installed and cap tightened to the marked position and cap tightened 1/16 to 1/8 more. Done ! Started and no leaks. Feel better now about it. Tks to all !
1 - 4 of 4 Posts
