3.8 engine turns over but does not start.
3K views 9 replies 7 participants last post by  LEVY
#1 ·
engine turns over but does not start.battery was dead from lack of use.charged battery.also radio does not come on when key put into acc mode
#5 ·
Starter relay?
From a Chrysler Tech on another site... (but, if you can swap a relay of the same type to try would be my 1st choice. However, his way debugs out other issues to find the problem.)
Instrument lights go out and a click at the fusebox would lead me to believe that it is either a relay or a starter issue.
Performing the starter relay test.
(3) Perform a visual inspection of the starter/starter solenoid for corrosion, loose connections or faulty wiring.
(4) Locate and remove the starter relay from the Power Distribution Center (PDC). Refer to the PDC label for relay identification and location.
(5) Connect a remote starter switch or a jumper wire between the remote battery positive post and terminal 87 of the starter relay connector.
(a) If engine cranks, starter/starter solenoid is good. Go to the Starter Relay Test.
(b) If engine does not crank or solenoid chatters, check wiring and connectors from starter relay to starter solenoid and from the battery positive terminal to starter post for loose or corroded connections.
Particularly at starter terminals.
(c) Repeat test. If engine still fails to crank properly, trouble is within starter or starter mounted solenoid, and replace starter. Inspect the ring gear teeth.
STARTER RELAY
WARNING: CHECK TO ENSURE THAT THE TRANSMISSION IS IN THE PARK/NEUTRAL POSITION WITH THE PARKING BRAKE APPLIED. THIS MAY RESULT IN PERSONAL INJURY OR DEATH.
RELAY TEST
The starter relay is located in the Power Distribution Center (PDC) in the engine compartment. Refer to the PDC label for relay identification and location.
Remove the starter relay from the PDC as described in this group to perform the following tests:
(1) A relay in the de-energized position should have continuity between terminals 87A and 30, and no continuity between terminals 87 and 30. If OK, go to Step 2. If not OK, replace the faulty relay.
(2) Resistance between terminals 85 and 86 (electromagnet)
should be 75 ±5 ohms. If OK, go to Step
3. If not OK, replace the faulty relay.
(3) Connect a battery B+ lead to terminals 85 and a ground lead to terminal 86 to energize the relay. The relay should click. Also test for continuity between terminals 30 and 87, and no continuity between terminals 87A and 30. If OK, refer to Relay Circuit Test procedure. If not OK, replace the faulty relay"
#6 · (Edited)
Starter relay?
STARTER RELAY
RELAY TEST
Did you read the OPs title? "engine turns over but does not start." That tells me the starter is rotating the engine but the engine has no ignition aka won't start/run. His starter relay and starter are doing just fine. If he turned the key and heard nothing, then he may have a starter relay or starter problem. Not the case here.
#8 ·
First thing, first...Welcome to the forum.
Year, make, model, engine is always a great place to start. I found it convenient to make a signature for myself that has that information.
Some builds have particular faults that are 'common' to a particular model, engine, or year (s)
Spark - fuel - compression.
Marvinstockman in post #4, suggested to try a shot of aerosol ether "Starting Fluid" (I've also used an unlit propane torch for this test)
If it goes VROoom or coughs, then you have verified spark and compression and then we know to help you figure out fuel supply (tank, pump, filter, injector, etc)
Oh, one last thing... Is there fuel in the tank?
Welcome, Cheers!
Reactions: Mopar-Mofun
