1 - 3 of 3 Posts
I got a tech @ the Chrysler dealership to print off these specs for me & I thought I would share them with everyone. I had them check my tranny fluid level so I can now go buy a universal dip stick, scribe the correct fluid level on it (after up to temp. of course) & be able to check it myself. Also checked on all recalls for my '09 T&C Touring, only 1 left to do - replace the radiator cap - they took care of that - now all caught up. He mentioned some factory extended warranties on some stuff, but sorry... I can't remember them so everyone should inquire their dealer about it. I remember him saying some brake stuff, suspension stuff.
Mike :thumb: I AM NOT RESPONSIBLE OR LIABLE FOR ANY MISUSE, MISINTERPRETATION, OR MISAPPLICATION OF THIS INFORMATION
FRONT SUSPENSION / FRONT / SPECS
Description & FT LBS
Ball Joint Nut = 20 + 180 deg. turn
Brake Caliper Adapter Mounting Bolts = 125
Brake Shield Mounting Screws = 6
Crossmember Mounting Bolts = 120
Fore/Aft Crossmember Forward Mounting Bolt = 83
Fore/Aft Crossmember Rearward Mounting Bolts = 41
Hub & Bearing Mounting Bolts = 37
Hub Nut = 118
Lower Control Arm Front Bolt = 114
Lower Control Arm Rear Bolt = 114
Stabilizer Bar Bushing Retainer Screws = 33
Stabilizer Bar Links = 65
Steering Gear Heat Shield Mounting Screws = 6
Strut Body/Tower Mounting Nuts = 21
Strut Clevis to Knuckle Nuts = 65 + 90 degree turn
Strut Rod Nut = 48
Tie Rod Jam Nut = 55
Tie Rod Steering Arm Nut = 55
Wheel Mounting (Lug) Nuts = 100
DIFFERENTIAL & DRIVELINE / HALF SHAFT SPECS
Description & FT LBS UNLESS OTHERWISE STATED
Bolts,Heat Shield = 124 INCH LBS.
Bolts,Caliper Adapter to Knuckle = 125
Nut, Hub = 118
Nuts, Front Wheel Lug = 100
Nut, Tie Rod End to Knuckle = 55
Nut, Strut Clevis to Knuckle = 65 + 90 degree turn
Bolts, Strut Damper to Steering Knuckle = 65
Bolts, Disc Brake Caliper Adapter = 125
10mm Bolts, Intermediate Bearing to block = 39
FRAME & BUMPERS / FRAME SPECS
ABS ICU Mounting Bracket Screws to Crossmember = 37
Front Engine Mount Crossmember Mounting Bolts = 41
Front Fore/Aft Crossmember Forward Mounting Bolt = 83
Front Fore/Aft Crossmember Rearward Mounting Bolts = 41
Front Suspension Crossmember Mounting Bolts = 120
Front Suspension Crossmember Support Bracket Mounting Bolts = 40
Rear Engine Mount Crossmember Mounting Bolts = 41
REAR SUSPENSION SPECS
Axle Parking Brake Cable Bracket Bolts = 55 INCH LBS.
Axle Trailing Arm Bracket to Body Bolts = 40
Axle Trailing Arm Pivot Thru-Bolt = 129
Brake Caliper Adapter Mounting Bolts = 74
Hub & Bearing Mounting Bolts = 41
Shock Absorber Lower Mounting Bolt = 55
Shock Absorber Upper Mounting Bolt = 55
Track Bar Mounting Bolt Nut = 60
Wheel Mounting Lug Nuts = 100
Anything for the lower front engine mount to the front cross-member? I pulled the bolts to lift up the engine and trans a bit to get at my front lower control arm bolt on the driver's side because the balljoint would not come free of the knuckle no matter how hard I beat on it. It was the only way I could remove the cv axle. I messed with that ball joint connection to the knuckle for hours before I had to try something else.
The new output shaft seals were somewhat difficult to do, but I am almost done with the project, though.
1 - 3 of 3 Posts
