Ok I’m hoping to get a little bit more info from this post. I’ve got a couple issues with my wife’s TC first one is after replacing the strut towers a couple months back my wife started hearing a popping noise when she turned the wheels. Upon a closer look I noticed that what appears to be a rubber bushing at the top of the tower right above the spring was actually twisting a little when the wheel was turned. Is there a reason why it’s doing this? Or a way to stop it? Second, for a month or so every once in a while the engine would rev up real high when taking off and the transmission would not change gears. If you stopped and then done it manually it would work fine or if you shut it off and restart it then it would go back to normal. I’ve searched the forums over these issues and haven’t found a clear distinct answer yet. Can someone help us out?
