1 - 6 of 6 Posts
I had an experience where the transmission would not up shift. Stopped the car went from park / reverse / drive after shutting the car off. Works fine but this problem doesn't fix itself.
Year?
Miles?
History of transmission problems?
Low fluid?
Old fluid?
Wrong fluid?
Checked for a code, P0750
Oh well
What causes the P0750 code?
  • Faulty shift solenoid A
  • Low transmission fluid level
  • Dirty or contaminated transmission fluid
  • Poor electrical connection for shift solenoid A
  • Valve body assembly faulty
What are the symptoms of the P0750 code?
In all cases the Check Engine Light will be displayed on the dashboard. The most common symptom is the vehicle may not shift from 1st to 2nd gear or the shift will be very rough. A decrease in fuel economy may be noticed in addition to a vehicle that runs poorly or appears to misfire.
Check your electrical connections and fluid level.
For a quick fluid level check to get meaningful results:
Reactions: Baron
1 - 6 of 6 Posts
