1 - 12 of 12 Posts
I bought a cheap used 2013 Dodge Grand Caravan that I was told has a bad transmission. It's currently throwing the following codes: P0740, P0933, P0868, and P0869. The latter codes represent pressure too low and too high, respectively. Is there a common failure mode that causes this? Might it just be a bad line pressure sensor or solenoid? I noticed the P0933 code is potentially a sensor issue as well.
I did a resistance check of the sensor and solenoid(in fact, all of the solenoids) and they checked out.
Dirty fluid/filter commonly cause pressure codes.
It's something that should be changed often that NO ONE does.
Unfortunately I tried replacing the filter/fluid already.
Without further diagnosis, it would just be throwing parts.
It could be a failed pack, but again, without proper diagnosis, it's just a toss.
Discussion Starter · #5 ·
Any idea how much a diagnosis would cost? Is that something a private shop could do or would I need to take it to the dealership?
Depends on the shop.
My local shop will plug in and read data in real time for $150.
I'd personally stay away from the dealer, in my experience, they're idiots.
The issue is going to be with having anyone willing to diagnose the issue instead of just saying "yep, it needs a transmission". They don't want the diagnostic money, they want the $4500 transmission replacement.
Discussion Starter · #7 ·
There's a local shop that's highly rated that I may take it to. I'm going to be upfront about doing the transmission replacement myself if it comes to that so hopefully they don't try to upsell me on that.
I tried the data stream myself but I wasn't really sure what to look for. Sometimes the pressure was close to the target(within 1-2 PSI) and sometimes it was ~30 PSI too low. I wasn't able to catch it going above the target PSI.
Discussion Starter · #8 ·
I have an appointment for Friday to get the van looked at. The guy on the phone said a common problem is that the transmission line has a leak. Does that make sense to you? I guess if the fluid goes pan -> filter -> pump -> radiator -> solenoids that makes sense but I assumed the fluid was pumped through the radiator at the very end. I don't have any reason to believe that's the case though.
If you already replaced the fluid/filter and saw no signs of leakage, it's doubtful it's a line.
Discussion Starter · #10 ·
I forgot to mention that I already replaced the fluid/filter so they may think I'm just low on fluid. When I was doing the replacement I wasn't looking for leaks at all to be honest. I could definitely have missed a leaking line.
I wish you luck that it's just low fluid/leaky lines.
Discussion Starter · #12 ·
Just got it back from the shop - lines are leaky and transmission is cooked so I'll need to replace both. In fact it looks like a previous technician crushed one of the lines so there wasn't proper flow to the cooler. I'll be putting in a new torque converter too. Most likely will get all the parts I need from a junk yard - looks like I have a new weekend project!
1 - 12 of 12 Posts
