1 - 5 of 5 Posts
I had a popping noise that we finally traced to the sway bar. It is broken off at the bushing on the right side. The part has been discontinued. Can anyone help me get one?
Mine broke on that same side about 10 years ago. (It was still an available back then)
The parts look up shows 2 sizes diameters: standard 5272205 and HD 4856003 which is what my Sport uses.
They are interchangeable if you also replace the 4 bushings too.
You might get lucky and find an HD one?
If not there is always the bone yard?
There is a standard one in Berlin? The PN has changed to 4856130.
http://avto.pro/part-5272205-CHRYSLER-142/
If you open this link in Google Chrome it can translate it for you.
Since the flag you are flying is US I think a wreaking yard is going to be a better option. :)
Woody Status
The old 86-95 FWD cars used the same sway bars (Sundance, Acclaim, Dynasty, Lebaron, L-bodies)
Or you can buy a new one with end links instead of bushing here >FWD Sway Bars
Those aftermarket bars look like a great alternative.
I would be looking to install the links pins the other way around to gain just a little more ground clearance though. :biggrin:
1 - 5 of 5 Posts
