1 - 8 of 8 Posts
I have a 2002 dodge Caravan SE and It does not have ABS , but the ABS , Brake and also a notice saying Trac off has appeared .. Can anybody here give me some ideas as to why these light came on and how to get them off.. I do not see any codes...Thankyou ..
If there are sensors at your wheels, then you have ABS. If front ABS sensor malfunctions, the traction control will be affected.
There could be an ABS fuse that you can remove. Take a look and try that.
This van has no ABS ,there are no sensors at the wheels and there is no option to turn the Trac on and off ...
Disconnect the battery (negative cable) and reboot your computer(s).
Reactions: LEVY
1 - 8 of 8 Posts
