AC Fully Charged, but temp won't get below 65 deg....???
7453 Views 31 Replies 9 Participants Last post by  marvinstockman
Hey guys!
I've got an 03 3.8 with Climate Control, we replaced the compressor last year but it has never really gotten "Cold"... it does get "Cool" when you're running down the highway, but I still have to have it on high the whole time.... even with all three zones on "Lo".... I tested the temp today and the lowest it got down to was like 71 deg...
Things I know..
Charge is good with no leaks
I have always kept the cabin filter changed and in good shape
I've hosed down the condenser coils the best I could with out removing anything
Fans are on
tube in engine bay is cool or borderline cold.. but not "COLD" like it should be - Ice cold or frosted up
Rear unit is producing the same or similar discharge air temps
I haven't checked the high side, thinking about picking up a cheap set of gauges from harbor freight to test.
I don't think the compressor is short cycling or anything but haven't had a chance to check that our for sure yet.
Didn't know if somebody has had similar issues and if so, what the fix or problem was?
Rick
21 - 32 of 32 Posts
AC condenser doesn't gets internally "full of crap".
Condenser can only get externally damaged by a physical shock causing reduced internal refrigerant flow or leak or by "external" debris blocking air flow.
There are some "filters" in the system that will catch any impurity or humidity in the system. Even a catastrophic compressor failure wouldn't damage the condenser, some people recommend replacing a condenser after a compressor failure just to be on the safe side, but is not really necessary if you have the equipment to do a thorough cleaning and know how to use it.
Yeah, I don't know what my malfunction is, but I try to be helpful, often to my own detriment...
Somewhere in my journey's and reading's I came across an reference to folks saying that today's condensers are manufactured differently these days and that when they begin to clog internally, they loose their efficiency to shed superheat. And that the internal passageways or perhaps the flow path does not lend to being flushed like the older vehicle condensers used to enjoy performance enhancement from condenser flushing. Also, in the big scheme of things, that the cost of the aftermarket parts is so inexpensive, that to go another hundred when repairing a system, you might as well do that too...
So, even with the a/c flush machine I believe that flushing (internally) a condenser rather than replacing one is not the better course of action.
But YES, keeping the outside of the condenser clean is also a great advantage and you can get an aerosol cleaning solution at home depot. Spray it on, wait 10 minutes, gently rinse with low pressure garden hose, biodegradable.
.... as I pulled the cabin filter out I was blasted with HOT AIR out of the bottom filter access area/housing !!!!??!?! ... What the!?! .... Only thing I can think is that the blend door wasn't set up correctly?... but would that be hot air pumping through there... like is it drawing from the outside/engine area (I had just got home from St Louis and it was running in the driveway) ... or is the "Heat" on in the back ground or something...?
Uhhhhg!
yes, the hot radiator coolant is always flowing to the airbox. They use a restrictor as opposed to the earlier cars had an actual heater valve. The restrictor is in the heater hose running from on the engine, behind where the upper radiator hose connects. It will appear as a black PLASTIC hose coupling, and be careful as they get brittle with age and we have seen several of them broken and lost coolant because.
Just reminded me that I want to replace mine as it is likely 17 years old and brittle. I will get a Mopar part as opposed to any aftermarket junk (although someone was turning aluminum replacement parts on a lathe)
Anyway, my thought for you Werner (in an earlier post) was to gently try to temporarily clamp the heater hose to see if it made any appreciable difference. my thought was that is it did make a positive result then you could chase the blend door as 'leaking'
You could always bypass the heated coolant for the summer months but come October you will want the heat restored for fall in St Louis.
See less See more
I don't think Scotty Killman was the source of my belief but his argument (and demonstration) is similar to what I was thinking.
3
I some times watch that guy's videos, for entertainment only. He makes money out of videos.
Let's suppose you replace compressor but you don't even flush the system.
Debris will not reach the compressor again, there are a couple of filters in the system (Receiver Drier /Accumulator, Expansion Valve Orifice Tube) that will catch any debris.
AC evaporator is placed in front of the radiator, a cheap evaporator may get easily damaged by road debris, I will prefer to leave the OE in place.
That little thingy Scotty uses is not to flush the system, he's funny.
Scotty talks before thinking.
Reason manufacturers can get away with smaller condenser piping is, the design is completely different.
On the first drawing you can see older condenser, it was just one line, a big loop. Should that line get clogged or crushed, the whole system would fail:
Newer condensers are made of many lines (like a radiator), if one of those lines fail, the other lines are capable of doing their work.
That is the main reason manufacturers changed design, not to save money. Of course, they saved money in the process.
See less See more
Yeah, that guy is kinda like a quirky Dennis Hopper. Sometimes I wonder if he is krunk in the videos. I watched a few more last night, they can be entertaining for sure but... I must admit that although his delivery is a bit odd, his philosophy is similar to my own. I heard him say several thing that I myself have said over the years.
Levy, your diagrams and information is great. I certainly am not disputing what you are saying and I agree.
A few points.
While the drier assy would be a filter of sorts, if you are catching debris in other areas such as expansion devices or orifice tubes, you would have a whole new world of troubles. In fact the older vehicles it was a good idea, although few seldom performed this maintenance, it was a good idea to replace the acc/driers due to time, because the desiccant could become saturated and/or the bag that held it inside would/could deteriorate and send its own form of junk through the system.
What I was trying to say was the point, that over time, especially after a compressor greanades, that SOME of those tiny orifice tubes will become clogged and that will result in lost efficiency. If 10% are clogged, then the condenser is only able to transfer 90% of the heat it has scavenged from inside the cabin to outside the vehicle.
Yes, the system will continue to cool, just not as efficiently and that is what Werner1 is experiencing. It gets cool, but not cold enough.
Perhaps he is going through the change and is experiencing hot flashes. I often get them when consuming guajillo chiles with lunch....
See less See more
Reactions: 1
A few points.
If you replace a compressor, it will be out of warranty if you don't also replace the drier and filter at the same time.
That being said, you must repace drier and filter everytime your system is serviced (No ifs, ands, or buts, every time refrigerant is replaced).
Okay so I had a little bit of time to double-check some things tonight...
1 - I pulled the recirculation actuator off and confirm the positioning of the recirc. Door,... it was rotated in the correct position towards the passenger door with the recirculation function off on the controls.
Next I visually inspected the Actuator motor as I turned the recirculation feature on Via the control panel, but motor did not move.... instantly thought motor was dead, but since I was into it this far decided to check voltage. No voltage present when the feature is on or off. Didn't see any blown fuses or anyting but I'm not sure which circuit controls that recirculation door motor?
I manually rotated the recirculation door so that it recirculates the inside cabin air I will give that a test tomorrow to see if it helps the AC keep up....
3
Finally got a chance to get up this morning and put the gauges on the van while it was still cold. Here's the results of my testing this morning...
Static Pressure @ 83°/55% rh = L/88.5 - H/88
I started the vehicle and let it warm up a little bit with the air conditioning on Max Lowe with the recirc door closed here are those results
L/44 - H/215 - lowest in Cabin temperature coming out of the center vent was 62°
Decided to take it down the road for about 5 minutes at 50 miles an hour Louis achievable in Cabin temperature was 56° @ 84° outside temp.
When I got home I left the van run at idle for a few minutes and then put the gauges back on it to test
L/69 - H/245 @ 86°/51% rh - Kevin discharge Air at this point was 69 degrees
See less See more
Any thoughts on where to proceed with this from here...?
Thanks,
Rick
Attach a bypass to the heater hose before it gets to the heater core. You can drain and save the coolant before you detach the hose.
Do not use this chart for PSI readings, only for Air Temp coming out of vents
I found two posts with this chart while researching my 5th generation Chrysler Town & Country A/C woes. This reference to it says not to use this for PSI readings. freggie, or anybody else, can you please clarify why this shouldn't be used for PSI readings?
The other reference is here: 2013 T&C Air Conditioning Diagram
(Also, sorry for necroposting, I can start a new thread asking about both charts as references if mods so desier.)
Well, I'll mention at least one part of the answer. The two charts aren't actually the same. I thought they were, but actually looked at the numbers instead of just the words in the posts around them. I still wish there was more clear information about this on these forums. I highly doubt A/C shops empty and refill to the spec under the hood, they likely use high/low pressures based on temperature and relative humidity.
Shops have a machine that evacs, pulls a vacuum, and refills all by itself. The mechanics can go on and do something else while waiting for the machine to finish.
21 - 32 of 32 Posts
