Just an update. My recall was taken care of on my 2008 Chrysler Town and Country WIN module so I have the newer improved one that hold the key FOBIK in better and doesn't let it switch to acc while driving. But mine was never a remote start van. So I am adding OEM remote start and tomorrow taking it to the Stealership so they can unlock Sales code XBM. I am not one to do someone to do something half way but I also question sometimes why oem does some of the stuff they do. SOooo I felt brody and added the extended range antenna connector to my WIN module. It is an FAKRA male, right angle "H" code amphenol connector. I took the "feet" on it and ground them down some, and the connector and ground it down some too. The whole in the WIN module had to be modified to reverse solder this thing in so I could solder it in with everything together. I took the back off my WIN module careful NOT to remove the board as that tents to break those hair thin antenna wires to the actual FOB reader. I soldered the amphenol connector in and got a good tone at least to where it is soldered and with no ill effects on the WIN module. So tomorrow when we unlock it, I guess we will see if it really does extend the range since I got a used extended range antenna from the junk yard of the same one I got my hood switch and connector from. My FOBIKs I just changed the "skin" or rubber to, over to ones with the remote start switch. Clicks good we'll see tomorrow. Will post an update if these WIN modules are hackable to make them remote start (WITH EXTENDED RANGE) ready. BTW as a disclaimer this is informational ONLY I take NO responsiblity if you jack up your own WIN module, I hacked mine knowing the possible consequences.
