Giving this a try for now:
As of March 18th 2023, Stickies, with no new Posts since October 1, 2022, are grouped here:
www.chryslerminivan.net
MotorCity Mechanic Uploads
I have watched videos by David Pike on MotorCity Mechanic and find them done quite well. Not a rush job, covers the bases. There's a lot of videos on the site pertaining to Chrysler products. Here's their complete site listing, it's worth browsing through: Uploads From MotorCity Mechanic...
HD Brake Upgrade DIY
I never got around and also forgot to make a thread about my HD brake upgrade on my 2009 Caravan, which others had been asking me to make for some time now. I upgraded my brakes because they were due for new pads and rotors all around, and the front had the braking shake (sometimes quite bad...
5th Generation - Brake Types/Modifications
The 5th Generations can be fitted with a regular single piston brake package or a heavy duty dual piston package, depending on year and options selected. The regular brake package can be upgraded to the heavy duty package. This Sticky on 5th Generation brakes starts out with reference to these...
5th Gen. Torque Specs
I got a tech @ the Chrysler dealership to print off these specs for me & I thought I would share them with everyone. I had them check my tranny fluid level so I can now go buy a universal dip stick, scribe the correct fluid level on it (after up to temp. of course) & be able to check it myself...
Radio Information Thread
2008-2010 Radios Media Center 130 (RES) - AM/FM/Single CD Player/Aux Media Center 130 (RES + RSC) - AM/FM/Sirius/Single CD Player/Aux/Sirius(?) Media Center 230 (REQ) - AM/FM/Sirius/6DVD Changer/Aux/Sirius(?) Media Center 430 (REN) - AM/FM/Single DVD/Aux/HDD/Sirius(?) Media Center 730N...
User Programmable Features (without an EVIC)
Key Fob Programmable Features (from 2008-2017 Owners Manuals and/or User Guides) • The following features may be programmed by using the Key Fob transmitter or the ignition switch and driver's door lock switch. NOTE: Pressing the LOCK button while you are inside the vehicle will activate the...
Uconnect Module DIY {PIC HEAVY}
So the 2015 GC I bought came with a 430N-RHB radio, but no uconnect module (so no bluetooth for the phones). Here is a DIY of how to install the module after the fact. It was really easy to do. Mopar kit #1-82212159 Tools Needed: Phillips Screwdriver Torx #10 Driver (Steering Wheel) Torx...
