Can't seem to get the mirror bracket off as I believe the last bolt is underneath it. Could someone please inform me of how.. Buy the way it's the passenger side fender I'm trying to replace. Thank you allen.ogden
Open the passenger door! You will see 2 screws on the mirror end bezel.The bigger flat blade screw and the phillips screw can be removed. (The phillips screw holds the bottom trim piece below the mirror.) Slide the trim piece toward the rear and out away from the body. This will reveal 2 more screws that were hidden by the lower trim piece. Remove them and unplug the connector for the electrical movement of the mirror. Re-install by reversing the steps.
