1 - 15 of 15 Posts
2012 dodge caravan am/fm band stopped working but Sirius is working and so is aux output any suggestions at what I need to do . I already tried disconnecting battery and also checked fuses they seem to be ok
I had the opposite problem when I got my van... the Sirius did not work but AM/FM did. I had to get a new (used) radio.
When you click on AM or FM does it do anything? what model radio (its in the lower right corner of the front) if you go to the system information tab you should see the application version... what version do you have?
welcome to the forum , it sounds to me like there's a problem with the radio antenna , the Sirius has it's own antenna , maybe a wire has come loose ?
Here is the back of the head unit (this is a 2014, so yours may be different). on the right side are 2 snap connectors. the WHITE one is for the AM/FM antenna. (The yellowish is the Sat ) This wire runs behind the driver side lower dash and has a connector there (could not find a photo) before it exits behind the right front quarter panel and up to the antenna mast. If by not working, you mean no reception then any connection along the path to the antenna could be your problem.
I have the same problem. When you select AM/FM it selects the radio stations but no sound, not even static. About every 20th time I select the AM/FM button you can hear the radio for a few minutes then it goes away. I removed the radio and reconnected all the connections and blew dry aerosol air in the cavity of the radio... no change. Any ideas?
Sounds like you have a bad solder joint somewhere . You can try and pull the radio apart and hit all the joints, otherwise you are probably looking at a new or used radio .
My 2011 caravan has same problem. CD player works, but the am/fm radio is intermittent. I found that when I removed the radio and wiggled the white antennae wire, that was the culprit. The white plug sticks out too far so it hits the air supply to the windshield. In the photo above with the white and red (Sirius) ant plugs, their white has a 90 degree turn. Mine doesn't, so it sticks out too far (to the van's front) and has been compromised by rubbing on the plastic ducting. I need to go in and resoder the broken joint perhaps.
chrysler 200 antenna wire
Lost am/fm radio, satalite works fine, am/fm antenna wire damaged, need to get a replacement from back of radio to right front kick panel, can anyone advise were to get it, chrysler tries to tell me it is part of the wiring harness and want rediculous money :(
My 2012 RES radio with satellite and blue tooth, the radio cuts off, every other function works. Check antenna connections which are OK. It seems like it's overheating. Does anybody know if the radio's cooling fan runs all the time, or only when hot? I've pulled the radio out when it stops without turning it off. Its awfully warm inside the cavity despite heat directed to floor vents, the radio's fan does not run. Just noticed 11,000+ views, must be a common problem.
For most problems described in this thread - no FM/Am radio. The problem probably lies in in the auxiliary plug in. This disconnects the radio when using the plug in. My radio suffered from this, sometimes working and sometimes not, sometimes the radio playing with my cell phone plugged in. It seems the plug in is not very robust.
Take the radio out and have a good technician fix the component or replace it
There's obviously a problem
I am having the same issue with my 2012 Caravan. One day, the FM radio mysteriously stopped working. AM as well. I then watched the video on how to removed the stereo and found that the Antenna was firmly in place. The,, even more mysteriously, it started working again. Then, it stopped again.
So far, it has worked for a few days now, but at any time it could stop. I suspect it's an internal tuner issue, as some others have pointed out.
I was going to try to find a used unit at the junk yard, but there is the anti-theft function as well as the Sirius satellite connection that needs to be considered when doing this.
However, with 319,000+ miles, it's getting close to being replaced anyway.
Dealing in electronics, I put this one on the manufacturers...
I have found the fix for the radio antenna loose solder joint, open the radio, once out you need to remove the front
control face, then remove the 4 screws that hold the board down, then remove the wire cable to finally free the board for work. , follow the center antenna trace and solder the traces that follow, you'll need a real small solder tip to resolder the 10 components that follow. Good luck!!
2012's had straight antennae plug to rear of unit, with not enough clearance when radio is pushed all the way into mounting hole, stressing antennae socket connection on circuit board. Subsequent years, the antennae lead plug is 90 degree type, which solves the clearance issue.
1 - 15 of 15 Posts
