For the twelve years that I've had my 1996 LE, there have been glitches in the electronics. At widely interspersed times, the rear window wiper will turn itself on, or the radiator cooling fans when the ignition is off. Twice the instrument panel went dark, fixed by switching off the ignition and back on. Once the transmission park-reverse-drive indicator showed all engaged even though it was in drive.
But the most common symptom is the door locks unlocking themselves at random times, usually about the time you've walked 30 yards from the car, and you hear the "click". I removed the door lock fuse for that one.
I've seen one video online for tracking down the door lock issue, but it involved a specialized piece of equipment for recording voltage spikes and determining from where they originated. The problems can't be recreated at will, so even if a garage had such a device, I probably couldn't get the spike to happen when it was connected.
Any ideas?
Any ideas?
