There have been a dozen or more posts over the years on a parasitic power draw that kills the battery. I have yet to find one that has been solved. I have the same issue. I am drawing .75 miliamps when the car is off, and has rested. i traced the circuit, and found that on the IOD fuse, if i disconnected the instrument cluster, that removed the parasitic draw. I did the self test on the cluster and it says its fine. So it is either one of 3 things, a bad instrument cluster, which is available used for about 50 dollars, or the body control module, which costs about 400 dollars programmed from a shop on line, or a short circuit. if the instrument cluster is disconnected, the power draw drops from .75 to .04 miliamps. with everything connected and ready to drive, the meter will sit at .75 for about 30 seconds, then drop to .04 for about a second, then go right back to .75. this cycle never stops so long as the instrument panel is connected. once the instrument panel is disconnected, the draw drops to .04 and stays there. something keeps waking up the circuit. has anyone ever solved this without going to the dealer and paying a large amount for a car worth a small amount ? what is the correct parasitic draw for a 2001 caravan that does not kill the battery after sitting for a few days ? thanks for any suggestions.
