Just installed my sun sensor and turned on my auto headlights. For anyone wanting to do this mod it is fairly easy. My van came with manual headlights and manual climate controls. For this mod you will need the following.
Either alfaobd or diagfca to turn on the auto headlights setting.
Start by installing the headlight switch, move to parking push in and turn and the old switch pops right out, simply plug in new switch and push back into dash. Remove radio and heater control panel. The sun sensor only has 2 wires and they connect into the blue connector on the back of the climate control panel. My van already had the wires running into the connector which means that they are probably in the wiring harness, but after taking the dash apart twice trying to find the connector in the harness I came to the conclusion that you cannot get to that part of the harness where the connector would be.
Take the connector and add 2 wires to pins 1 and pin 4, you will have to add some wire to reach down to the heater controls. I used wire taps to connect the sensor wires into the wires going into the heater controls. Pin 1 from the sensor goes into A6 white/violet on the blue connector in the back of the ac/ heat controls. and pin 4 on the sensor goes in A9 dkblue/dkgrn on the same connector.
Remove plug and install sun sensor on top of dash, plug in connector. Load up your alfaobd or DiagFCA and turn on auto headlights option.
Congratulations you now have auto headlights.
56046258AD | Headlamp Switch with auto headlights, with fog lights. |
68230115AB | Sun Load Sensor with auto headlights, without auto climate. |
68080566AA | Wiring-4 Way connector kit for the sun sensor. |
