Battery Drain on my 2000 Town & Country
8719 Views 5 Replies 6 Participants Last post by  Earl D
I am measuring still have about .1 amp draw with everything off after several hours of shutting the ignition off. Tried pulling fuses and find the only one that reduces the draw is the EATX fuse. When I pull that the draw drops to about .04 amps or less. When I reinstall the fuse the relay snaps and the draw goes back to .1. I tried to pull the EATX relay but no change as long as the fuse is in. Also switched a couple of relays but no change. Any ideas what might be the solution?
1 - 1 of 6 Posts
The relay is normally controlled by TCM and is used to supply power to the solenoid unit. It shouldn't be closed with ignition off. You might need a wiring diagram to solve this one.
1 - 1 of 6 Posts
