1 - 1 of 1 Posts
I've been having a problem with the BCM thinking that liftgate is open, and a chime that would not shut up. Disconnected liftgate switch, thinking that would stop the chime. No difference. Decided that it was a short or bad connection somewhere in the harness. So, opted to just remove chime speaker. Learned that speaker is located in BCM. Tried muffing speaker, no difference. Removed BCM and deleted speaker from BCM board. Re install BCM, and no power anywhere. Where I might've make a mistake is I pulled IOD fuse with BCM. Does anyone know if speaker needs to be a part of board in order to make a circuit? All wire blocks are in the right spot. ( color coded ). Any ideas?
Seems this BCM was either replaced, recalled, or repaired in 2011..
Chase.
Sent from my LG-LS993 using Tapatalk
1 - 1 of 1 Posts
