1 - 2 of 2 Posts
I have two questions that I hope you can help me with.
I have installed a heater blower motor and resistor pack in my 2001 Grand Caravan (GC,ES w/3.8 and auto climate control). My concern is that not I’m sure what the default location of the venting-baffle around the motor should be (mostly clockwise or mostly CC?) and how much rotational travel the baffle should have. The way I have installed now; the baffle only rotates 2 or 3 inches.
??Do you know the default resting position the baffle should be set at in the off setting? And how much should the baffle be able to travel with or without having the servo motor attached??
Thanks in advance for any ideas you can think of.
1 - 2 of 2 Posts
