1 - 6 of 6 Posts
Hi All, owner of a newly purchased '13 T&C.
Wondering what folks feel is the best cell phone holder, i,e, doesn't block visibility or the vent, if possible.
The problem is, I have a Samsung xl in a protective Otter Box case, making it heavy, so it has a tendency to pull the suction cup holder off, especially at the wrong times, scaring the heck out of me.
I have 2 pull out cup holders, maybe a cup phone holder with an extension to raise it? Or a short holder on the dash that holds a lot of weight?
Any advice appreciated.
Those that you attach to the windshield works great. I don't own one but my daughter does.
Doesn't it cut down on visibility quite a bit? I assume you get used to it...
i own this
it's okay at holding ipads and a tank at holding phones, it supports itself in two spots instead of just on the windshield or just on the dashboard, this is key for stability
if you want to hold phones with it it will grab onto the top and bottom, it has a cut out for a charger to fit through but your phone may or may not play well with it
1 - 6 of 6 Posts
