1 - 9 of 9 Posts
For some reason when I turn on the headlights the brake lights stay on. When the headlights are off the brake lights go on/off as normal. All the other lights work fine (turn signals, etc.) except the passenger backup light which I need to check the bulb. Could a bad bulb be causing this? Thanks in advance for any suggestions to try.
You either have the wrong bulbs in the sockets for the running lights, or there is a ground problem in the rear lights. The power for the tail lights must be feeding through the stop filaments for some reason.
It's a 2000 Grand Caravan 3.8L . I can check the bulbs tonight when I get home. How can I tell if I have the right bulbs in the right sockets? I did notice that on the drivers side the taillight's top bulb is much brighter than any of the others.
Bad ground problem?
It's in your manual under light bulbs.
From the FSM:
EXTERIOR LAMP BULBS
CAUTION: Do not use bulbs that have a higher candle
power than the bulb listed in the Bulb Application
Table. Damage to lamp can result.
Do not touch halogen bulbs with fingers or other
possibly oily surfaces. Bulb life will be reduced.
If a halogen bulb is contaminated with oil, clean
bulb with denatured alcohol or ammonia based solvent.
LAMP-------------------------------------------BULB
Back-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3057
CHMSL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 921
Fog Lamp . . . . . . . . . . . . . . . . . . . . . . . . ... . . . 9040
Headlamp – Except T&C . . . . . . . . . . . . ........ . . . 9007
Headlamp high beam – T&C . . . . . . . . . . ........ . . . 9005
Headlamp low beam – T&C . . . . . . . ................... . 9005 XSLL
License Plate . . . . . . . . . . . . . . . . . . . . . . . . . . 168
Parking/Turn Signal . . . . . . . . . . . .............. . . . . 4157NAK
Tail, Brake, Turn Signal and Side Marker . ............. . 3057
Front Side Marker – T&C . . . . . . . . . . . ........... . . 194NA
INTERIOR LAMP BULBS
LAMP-----------------------------------------BULB
ABS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . PC194
Air Bag . . . . . . . . . . . . . . . . . . . . . . . . . . . . . PC194
Alarm Set (Security) . . . . . . . . . ... . . . . . . . . . PC194
Brake Warning . . . . . . . . . . . . . . . . ... . . . . . . PC194
Center/Rear Reading Lamps . . . . . . . .. . . . . . . . 578
Center/Rear Dome Lamps . . . . . . . . . . . . . . . . . 579
Service Engine Soon . . . . . . . . . . . ... . . . . . . . PC194
Front Door Courtesy . . . . . . . . . . . . . . . . . . . . 567
Door Ajar Ind. . . . . . . . . . . . . . . . . .... . . . . . . PC194
Front Header Reading Lamp . . . . . . . . .... . . . . . 567
Glove Box Lamp . . . . . . . . . . . . . . . . . . . . . . . 194
High Beam Ind. . . . . . . . . . . . . . . . . .... . . . . . PC194
Instrument Cluster . . . . . . . . . . . . . . ..... . . . . PC194
Instrument Panel Bin/Ash Tray . . . . . . ... . . . . . 161
Liftgate Flood Lamps . . . . . . . . . . . . .. . . . . . . 567
Liftgate Ajar Ind. . . . . . . . . . . . . . . . . . . . . . . PC74
Low Fuel Ind. . . . . . . . . . . . . . . . . . . . .. . . . . PC194
Oil Pressure Ind. . . . . . . . . . . . . . . . . . .... . . . PC194
Overhead Console Reading Lamps . . . . . . ... . . . 579
Seat Belt Ind. . . . . . . . . . . . . . . . . . . . . . . . . PC74
Engine Temperature Indicator . . . . . . . . ...... . . PC194
Turn Signal . . . . . . . . . . . . . . . . . . . . .. . . . . PC194
Visor Vanity Lamp . . . . . . . . . . . . . . . ..... . . . 6501966
Low Washer Fluid . . . . . . . . . . . . . . . . . . . . . PC74
Low Volts Warning . . . . . . . . . . . . . . . .. . . . . PC74
Cruise Indicator . . . . . . . . . . . . . . . . . . . . . . PC194
Discussion Starter #9
Problem resolved. It appears the the burned out backup light on the passenger side was causing this problem. Replaced the bulb and all ist well. Thanks for all the ideas and help.
1 - 9 of 9 Posts
