1 - 14 of 14 Posts
Need to replace pads & rotors on the front, 2010 Grand Caravan, 4.0 w/ tow package (heavy duty brakes? Not sure, but suspect so.)
There were after-market grooved rotors on the car when I bought it, and I'd like to go to standard rotors, but a good quality one. Also, I prefer a brake pad that sacrifices itself, rather than one that eats up the rotors. Ceramic vs. organic?
So, I would appreciate hearing you all's thoughts on this.
If you don't mind the dirty wheels, I would go semi-metallic.
Dodge-Chrysler started including Heavy Duty brakes on their minivans late 2012, I believe.
A fewer months back I replaced Pad/Rotors on all for corners with Advance Auto's Carquest Painted line mated with their Wearever Platinum Professional line pads. Great improvement in bite and stopping power over the stocks I had in the past. No complaints so far. Low dust, no noises, etc.
Sent from my LG-H872 using Tapatalk
I used the Wearever Platinum Ceramic Pads and Wearever Platinum Rotors. They are now Warped after 2 years...not impressed at least with the rotors. I just bought Power Stop rotors and pads...trying something new again!
Some Shops give lifetime warranties on their pads and rotors. Installation would have to be paid for though. This might be a consideration if you travel a lot and don't have time or don't want to do the work yourself.
If a vehicle has OE, or real good quality aftermarket rotors on it and they have lots of room left for turning them down, this would be a good option. The cost would be about the same as the cheap "white box" rotors that are commonly used, but would have higher chromium content.
White Box Rotors: these are the cheapest ones to use ordinarily. They tend to rust, even overnight, but if used daily, will last a long time. I have used a lot of these but won't be doing so for my 2016. I have seen them perform better and outlast the OE rotors on a 2004 Acura (Honda). Don't expect much and they will likely exceed your expectations.
Higher Chromium Content Rotors: less prone to rusting, more expensive, and the more commonly sold ones at a local NAPA store, so they told me.
Coated Rotors: these are the more expensive rotors and are more resistant to corrosion from road salt. http://knowhow.napaonline.com/what-are-coated-brake-rotors/
As for pads, maybe try something equivalent to OE. There are white box semi-metallic pads that work ok. I have used lots of them. Some people, that are hard on their brakes, may find the cheaper semi-metallic pads squealing on them. You get what you pay for. Semi-metallic pads tend to be more effective at slowing the vehicle down than ceramics, but they wear quicker and give off a noticeable black dust.
This web site has the pros and cons of "organic", "semi-metallic" and "ceramic" PLUS some "good", "better" and "best" pads to compare: https://www.autoanything.com/brakes/the-best-brake-pads-ceramic-or-metallic.aspx Interesting reading, so many choices. Anyone have experience with Wagner brake pads?
Hope this helps. Good luck. :thumb:
The power stop rotors and pads are nothing special. I had them a couple years ago. Pads dusted horribly and didn't last long at all. Rotors looked like STD white box variety. The got minor pulsation within 5-10k miles but never got any worse. I decided to retire then after around 65-70k miles. I have gotten much better service from Centric premium pads and rotors. The pads especially last much longer and the rotors are staying smooth even after our vacation towing thru mountains.
NAPA Ultra Premium rotors and ceramic pads. The Ultra's are thicker and heavier, last longer, cost more but not an arm and a leg. Ceramic pads have good feel and leave very little dust.
"Onyx Guard Protectant Prevents Rust & Corrosion On The Rotor's Hat & Vanes & Improves The Vehicle's Appearance" sounds good too.
Who makes the NAPA pads?
I don't know. I've always had good service from them though.
The T&C is my wife's and she comes down the steep mile-plus long hill into our town from work five days a week without downshifting because "It might hurt the transmission". The NAPA Ultra rotors and ceramic pads are the only ones she hasn't been able to kill in a year in any car she's owned. Probably glowing like a NASCAR short track car's brakes by the time she gets to the bottom.
Happy Birthday JohnnyO :birthday:
1 - 14 of 14 Posts
