I am replacing the water pump on my 98 Grand Caravan with a 3.8. I was removing the last bolt, the top right one, and it got very tight. Obviously never seize was not used
it was going fine until the bolt broke.
I got an ez out and bit, but the bolt is about 5-6 inches up from where I can drill it horizontally. If I loosen the upper passenger side mount, the other pulleys on the back side of the engine won't let the engine drop far enough. Looking at the other 4 bolts, they almost make a square. I think that the o-ring and some rtv would seal enough to hold the water pressure.
Has anyone had this issue and tried my remedy with any success?
