1 - 11 of 11 Posts
Hi, My 2005 Grand Caravan SXT is reading way off on the DTE fuel reading on EVIC. When I fill the tank, the DTE reading is around 248 miles or so. This is way low, and should be much higher around 300-320. I'm wondering if there is a menu on the Chrysler Star Scan, or aftermarket scan tool where this can be calibrated in any way. Just interested because it is very inaccurate. Thanks for any info. Bill
You can try the instrument cluster test feature per this link:
Reactions: sirsy2001
Drivin' Maniac
2002 Grand Caravan ES 3.8L
Your DTE is based on your most recent avg mpg.
Correct.
If I go around an anti-clockwise curve, my DTE increases! Boy, that was easy. 😇
Just like the overall MPG display which has been optimistic in every car I've owned over several makes, you need to learn to live with it.
PS: do you reset your MPG readout after filling up?
Discussion Starter · #5 ·
Correct.
I'll start doing that. Maybe resetting it will make it more accurate over time.
In winter I try to avoid going below 1/3 tank. You never know when you might get stuck in a blizzard and need to run the engine part time to avoid freezing.
sirsy, DTE is not based on a long term average. If so, it would be useless. It is really based on what is happening right now, and will change based on traffic conditions.
Discussion Starter · #9 ·
True. When I top the tank off and then calculate my fill up, I typically will get in the vicinity of 17 mpg, depending on the type of driving. I don't go far. So, once done, the DTE reading will show somewhere around 250 miles (to empty). I know that I can go up to and sometimes over 300 miles on the 20 gallon tank. I don't do it often, but I've tested it before. It is not good for the fuel pump I know. The DTE readout shows way too low. By design, or is there is something that can bring it closer into calibration? It may just be a gimmick that is not really expected to be too accurate, which is probably the case. Not a big deal, but curious if anybody else gets higher DTE readings that are more realistic.
Have you done the instrument cluster calibration yet? My 2007 DGC started acting up years back, couldn't depend on the overhead computer anymore. I did the instrument cluster calibration and problem solved. Coincidence or what, I don't know, but worth a try.
As for accuracy, the computer is off by about 7% on fuel consumption. Last three vans have been the same.
The factory trip computer is not accurate. I never look at mine. You can buy a ScanGauge.
1 - 11 of 11 Posts
