I have been chasing a no crank condition. I am not getting the ground from the PCM to the coil (# 85) on the starter relay. I also was not getting ground to the coil on the automatic shut down relay (# 85) on that relay either. I discovered a blown fuse, #17 20 amp for the ASD relay. As soon as I put a new one in it blew. I suspected a short in the PCM. I removed the PCM and looked inside but could not really see through the gel if there was an obvious issue. For laughs I re-installed the PCM to check some other parts of the starting curcuit and this time it did not blow the #17 fuse for the ASD relay. I still have the same no crank issue as well as no ground(s) to the coils in the relays.
By the way I can ground the #85 pin on the starter relay and get the starter to crank but not start.
History was the van would not start or crank. I conducted all the tests as outlined in the Haynes manual. I checked all the basics, connectors, under the Integrated Power module for corrosion, wires, the transmission range sensor etc. When I was done checking all of these things it did start. I thought it was a poor connection perhaps. However after a few starts with out driving, it was right back to no crank. I did get it to start again simply by checking it later in the day and it started right up but this time it stalled while running after about 10 seconds bringing me back to the no crank condition I am in now. Then the issue I described above.
Note: I do not have any codes when I check with my scanner. I was thinking a crank sensor perhaps even though it would still crank with a bad one no?
Before I buy a new PCM I would like to test mine. Can this be done? If so by whom? I am wondering if I have some other short passing through the PCM. I am not sure what to check next.
Any other thoughts please let me know.
