I bought a 2005 Town and Country that has had two unsuccessful ECU changes by a shady used car dealer's in-house mechanic, so I don't trust the part number from the current one. Do any of you know how I can get the correct part number?
It occurred to me that I have the order reversed if getting an oscilloscope isn't an obstacle.ScuzziOne, that makes sense. I couldn't see anywhere that any harness got close enough to the exhaust to be a concern.
I'm getting a P0344 - "Intermittent fault in the cam position sensor circuit" code that is often associated with wiring problems when a new cam position sensor doesn't fix it. I'll be going over the harnesses looking for abrasions or other signs of damage.
OOPS! I TYPED THIS ^^^ UP YESTERDAY AND SOMEHOW DIDN'T SEND IT
...continued:
I haven't had much time to dig deeper yet, but I was able to back probe the CPS connector and found 4.9v to 5.0v on the 5v reference wire and on the signal wire. There were no perceptible interruptions with poking, prodding, wiggling, tugging, etc. but the "intermittent" interval could be milliseconds on each revolution rather than now and then for an observable amount of time.
I don't think my scanner has live monitoring for this signal. If that proves to be true, I'll pull the wheel and inner fender off to back probe Connector #2 pin #34 to see if i get the same result, or if I have a bad wire.
While I'm there I'll check the crankshaft position sensor next-door at pin #35 and I'll get the PCM part number to compare to the part numbers identified above.
If that doesn't find the problem, I have the two next steps in mind which are:
1) running it with jumpers for each of the three wires and any combinations of the three to see what, if anything, fixes it; and
2) track down an oscilloscope somewhere and start looking for millisecond-type interruptions in those three wires. I'll do the same on the crankshaft position sensor while I'm there.
I think that is the end of the road for diagnosis outside of the PCM itself.
What did I miss?
You can order the OE as it's the Delphi part supplied to Chrysler.The information provided above by Atoman has "Good trip equal to zero". How does one resolve this issue. It seems like circular reasoning to me. In order to achieve a "good trip" I would need to not have the P0344 code, but I can't get rid of that code without having already had a "good trip".
Unless I have been cast as Joseph Heller's Captain Yossarian, I'm understanding this incorrectly, as such an obvious error would have been corrected in the 20 years since that was published. What is the actual meaning of this?
